Register
Login
Search
Issues Tracker
Home
Project
ยป
Roadmap
Change Log
Search
Issues
Queries
-- Select Project --
SMath Studio
SMath Studio in the Cloud
SMath Viewer
Home
Issues
View Issues:
-- Select a View --
All Issues
Open Issues
Add / remove columns
Export
RSS
Set properties for selected issues:
Category
Owner
Milestone
Affected Milestone
Type
Resolution
Priority
Status
-- Select Status --
Assigned
Due Date
* Enter a valid date
Reset Due Date
Select columns:
Votes
Category
Creator
Owner
Assigned
Type
Milestone
Affected Milestone
Status
Priority
Resolution
Due Date
Estimation
Progress
Time Logged
Created
Last Update
Last Update User
Id
Title
Votes
Category
Creator
Owner
Assigned
Type
Milestone
Affected Milestone
Status
Priority
Resolution
Due Date
Estimation (hrs)
Progress
Time Logged (hrs)
Created
Last Update
Last Update User
SS-4691
Linux (Ubuntu) AppImage is not opening
1
User Interface
Snowflake
Snowflake
smath
Unassigned
Unassigned
none
0.00
0
10/2/2023
10/2/2023
Snowflake
SS-4690
Undo doesn't cover description edits
1
User Interface
smath
Unassigned
none
0.00
0
8/24/2023
8/24/2023
SS-4688
Different bracket/parenthesis handling of sum(4) and sum(1)
1
User Interface
smath
Unassigned
none
0.00
0
8/11/2023
8/11/2023
SS-4682
UI glitch in SMath Solver - Extension manager 1.0
1
User Interface
smath
Unassigned
none
0.00
0
4/30/2022
4/30/2022
SS-4674
A previously saved file does not open. iPhone 6 plus
1
User Interface
chaus
chaus
smath
Unassigned
none
0.00
0
9/21/2021
9/21/2021
chaus
SS-4654
Spurious save requests when following links in unmodified files
1
User Interface
smath
Unassigned
none
0.00
0
11/24/2020
11/24/2020
SS-4653
7632: localization issue
1
User Interface
smath
Unassigned
none
0.00
0
11/24/2020
11/24/2020
SS-4650
NTFS Attributes or permissions preventing SMath from being executed correctly
1
User Interface
smath
Unassigned
none
0.00
0
11/6/2020
4/25/2021
smath
SS-4641
[Text region] formatting issues
1
User Interface
smath
Unassigned
none
0.00
0
9/14/2020
10/5/2020
SS-4639
Occasional incomplete rendering when expanding a collapsed area region
1
User Interface
smath
Unassigned
none
0.00
0
9/14/2020
9/14/2020
Show rows:
5
10
15
25
50
75
100
1 - 10 of 90
