Page History: Examples
Page Revision: 2010/01/05 12:31
Engineering
  • CEE Fluid Mechanics Test 1 - Prob 1 pdf zip
  • CEE Fluid Mechanics Test 1 - Prob 2 pdf zip
  • CEE Fluid Mechanics Test 1 - Prob 3 pdf zip
  • CEE Fluid Mechanics Test 2 Solutions pdf zip
  • CEE Fluid Mechanics Test 3 Solutions pdf zip
  • NASA's Atmospheric Model (SI Units) zip
Numerical methods
  • Runge-Kutta 4th-order for single 1st-order ODE pdf zip
  • Runge-Kutta 4th-order for systems of ODEs pdf zip
  • Runge-Kutta 4th-order for single 2nd-order ODE pdf zip
Statistics
