Page History: Examples
Page Revision: 2009/09/23 02:27
Engineering
Non-linear deflection of a flexible cantilever pdf zip
Bach chemical reactor pdf zip
Lateral force developed by a tire, using an early Pacejka model. pdf zip
Numerical methods
Lagrange interpolation polynomials pdf zip
Newton interpolation polynomials (forward finite difference) pdf zip
Newton interpolation polynomials (backward finite difference) pdf zip
Data fitting (single independent var., linear on parameters) pdf zip
Simpson integration with Richardson extrapolation pdf zip
Second order linear ODE - finite difference method pdf zip
Statistics
Normal distribution pdf zip
