A Wiki Template
Modified: 2019/08/15 07:19 by w3b5urf3r - Categorized as: English
this page is intended to be a reference template to write "a good" wiki page, nothing else
IN GREEN BOXES YOU CAN SEE HINTS AND SUGGESTIONS
A brief description of this SMath Studio feature.
A menu should be used when there are many sections or wide sections; this help the user to have an idea of the entire page content in a single view.
Edit
1st section
Lorem ipsum...
Edit
2nd section
Lorem ipsum...
Edit
3rd section
Lorem ipsum...
Edit
Known issues
to inform the developers about issues you found out use the forum: bugs&problems
There are several main known issues about ...:
  • 1st issue;
  • 2nd issue;
  • 3rd issue;
Only main issues should be written in the wiki; everything a user could reasonably think there should be but there is not. For everything else there's the forum :)
Edit
History
  • SMath 0.78 (stable): Added ....;
  • SMath 0.89.8 (Beta): Added ....;
As for the issues, only main changes should be written in the wiki.
But... why the history? If you share a worksheet, someone that use an old Smath Studio version could have some issue reading your file;
moreover opening an old worksheet, something could be changed. In any case it's useful to see in a fast way what changes.
Edit
See also
Edit
References
