Curve fit function?
Curve fit function? - Looking to do a pump curve fit - Messages
#21 Posted: 4/21/2016 3:48:18 AM
1,362 likes in 2,276 posts.
Hello Martin,
Very interesting, but does not work in 5346.
Your work sheet does not work either.
I can't reproduce the problem with the unofficial portable distribution.
If you use this from an usb stick, do you get the same problem on different computers?
#22 Posted: 4/21/2016 9:48:49 PM
Originally Posted by: Jean Giraud [url=/forum/yaf_postsm32927_Curve-fit-function.aspx#post32927][/url]Hello Martin,
I will try to isolate the problem. Actually Smth resides in only one of my 5 PC's.
Thank Martin, Jean.
