Beta: SMath Studio 1.0.8206 (20 June 2022) - Messages
#21 Posted: 7/5/2022 8:55:11 PM
WroteWhat does this mean for me as a Smath user ?
Simoly: hope some user of your SS version will catch/isolate the bug.
#23 Posted: 7/6/2022 3:38:05 AM
Hi avp. Try using eval() for ainterp().
Thanks, this is how the integrals are calculated, but the function containing the integral inside still returns an error. Accordingly, the final result of the calculations still failed to be obtained.
Proizvol'noe sechenie_no XLSX.sm (73.55 KiB) downloaded 1940 time(s).
#24 Posted: 7/6/2022 9:29:07 AM
#25 Posted: 7/6/2022 11:00:48 AM
WroteThe type errors your version reports is
wrt some limit(s) of the double integration.
Why specific to this version ?
I dont know. I wanted to know here why the calculation of integrals, which used to work well before, broke down after adding the ability to use the dimensions of units in integrals.
#26 Posted: 7/6/2022 11:54:42 AM
WroteI don't know. I wanted to know here why the calculation of integrals, which used to work well before, broke down after adding the ability to use the dimensions of units in integrals.
You have a good point about units in integral.
Attached is your saved working version.
Open in your latest SS. It may rescue the integrator.
God save the Queen and avp.
Cheers ... Jean.
Integrate Double Didactic Russia.sm (72.92 KiB) downloaded 1843 time(s).
#27 Posted: 7/8/2022 3:21:11 AM
Workarounds for the integration bug.
Proizvol'noe sechenie_no XLSX.sm (74.19 KiB) downloaded 1893 time(s).
Proizvol'noe sechenie_no XLSX.pdf (260.22 KiB) downloaded 1079 time(s).
#28 Posted: 7/8/2022 10:41:34 AM
WroteWorkarounds for the integration bug.
Hi, Alvaro.
The result is not correct. The result should be Kx = 1.233, Ky = 1.044
#29 Posted: 7/8/2022 1:09:49 PM
WroteThe result is not correct. The result should be Kx = 1.233, Ky = 1.044
... those values are same in my document.
You didn't report working/crap ?
#30 Posted: 7/8/2022 7:55:00 PM
Hi, Alvaro. The result is not correct. The result should be Kx = 1.233, Ky = 1.044
Hi avp. I hope the problems with double integrals can be solved, because the calculation of double integrals that SMath had was quite powerful. The only way to calculate Kx, Ky would be to discretize and integrate over the cubic splines curve.
Proizvol'noe sechenie_no XLSX.sm (77.48 KiB) downloaded 1841 time(s).
Proizvol'noe sechenie_no XLSX.pdf (287.16 KiB) downloaded 1040 time(s).
#31 Posted: 7/10/2022 8:11:01 PM
This document is adapted/doctored in native Smath 6179.
It does not scratch Smath a bit.
As you download, after it has finished
it offers to update: click close to be back SS 6179.
Re=download and let it update latest SS.
If you have red as it complained, probably the integrator
is freaked in that version ... hard to explain.
Cheers ... Jean.
Integrate Double Didactic Russia (3).sm (74.09 KiB) downloaded 1893 time(s).
Cheers ... Jean.
#32 Posted: 7/10/2022 9:10:02 PM
