How to solve these types of equations - Messages
nonlinear_kr.sm (8.26 KiB) downloaded 1171 time(s).
WroteMaxima's solve seems to provide multiple yet not all solutions.
Interesting, cause maxima in linux terminal can find all solutions.
I have tried, wxMaxima (gui of maxima) can also find all of them.
WroteHello,
It should be careful if the equations are a bit more complicated.
As far as I know, al_nleqsolve() is the only solver in SMath which will solve nonlinear equations in a pure numerical fashion (excluding solvers from Maxima and Maple plugins).
This "numerical thing" was mentioned here many times - maybe to many.
This is a good demonstation, thanks for your reply.
Since he choose a nickname "newbie" I wanted to keep it simple.
There are a lot of solver in smath, all with their pros and cons.
Which is a good thing I guess, diversity is golden.
If you can't find a solution with a function try another one.
Trying through simpler to complex is the proper way, at least this is my opinion.
Could you please set optimization to symbolic, expand the matrix, then set to none again?
Maxima may have found all solutions but can't show because of matrix reduced view.
Three dot to expand matrix doesn't appear if optimization is selected to none.
This is a cosmetic bug if I had to make a statement.
WroteWroteIf I have two non-linear equations with 2 unknowns x,y: f(x,y)=0 and g(x,y)=0. I know there are real roots and the ranges of the roots. How can I solve these in Smath?
1.f(x,y)=0 and g(x,y)=0 are implicit [= 0] in mathematical definition.
2. That they have real roots, you can't know in advance.
3. Solving in there means solving for their intersection
4. Visit this triplet solved.
Cheers ... Jean ... give your functions..
Contour SOLVE AstroidHyperbola.sm (22.66 KiB) downloaded 1276 time(s).
Thank you Jean. Please see attached my smath file. I tried all options but all gave me errors. The current one didn't give me any errors but took forever to solve (or ever able to solve it).Complex Equations.sm (47.29 KiB) downloaded 1251 time(s).
WroteWroteMaxima's solve seems to provide multiple yet not all solutions.
You are right, there seems to be a display bug. Thank you for pointing this out.
Optimization None doesn't properly co-operate with result ellipsis mechanism.
The resize handle is missing.
This is bad in two ways. First, you can't change the amount of displayed elements, second, you can't even see that there are suppressed elements.
nonlinear_kr1.sm (21.79 KiB) downloaded 1193 time(s).
WroteThank you Jean. Please see attached my smath file. I tried all options but all gave me errors. The current one didn't give me any errors but took forever to solve (or ever able to solve it)
Try to plot something as soon as possible.
Here, it computes in few seconds but complains
too many not defined, units don't match, result above max ...
WroteTry to plot something as soon as possible.
Complex Equations (1 to be doctored).sm (59.76 KiB) downloaded 1281 time(s).
At this point make the Units match.
I don't doctor units, they are against maths and my conviction.
Keep working hard ... Jean
Complex Equations (1 to be doctored).sm (64.43 KiB) downloaded 1328 time(s).
Wrote.... download this same updated in split part.
Thanks, Jean for giving this a stab. Let me try to remove all the units in the equations and see what happens.
Please use the attached file. No more units in the equations. Or use this block
Complex Equations (unitless).sm (50.11 KiB) downloaded 1278 time(s).- New Posts
