Matching units blamed to not match
Matching units blamed to not match - BTS Issue SS-26 - Сообщения
#21 Опубликовано: 08.08.2013 18:01:39
1 442 сообщений из 2 935 понравились пользователям.
"The variables should be assigned to their desired values only after the function is defined." sic!
That's true only if you don't use line() to define your function; in this case to avoid the behavior you must set the optimization of the function definition to "numeric".
ioan92 09.08.2013 01:45:00
#22 Опубликовано: 08.08.2013 20:03:58
kilele
kilele
All in all, SMath functions are called ALWAYS using call by reference also known as pass by reference.
That is, the function can modify the variable used as argument.
Look this post about global and local variables / scope of variables
This is a bit away from the original subject reporting a units bug.
#23 Опубликовано: 23.03.2014 07:35:58
1 353 сообщений из 2 264 понравились пользователям.
You might vote for the bug report http://smath.info/bts/Issues/IssueDetail.aspx?id=26 as the unit simplification issue is really nasty.
#24 Опубликовано: 24.03.2014 12:03:38
kilele
kilele
You might vote for the bug report http://smath.info/bts/Issues/IssueDetail.aspx?id=26, as the unit simplification issue is really nasty.
the link does not work because of the trailing comma, anyway this can viewed as vote buying, paypal me hard and I'll vote your bugs :d
#25 Опубликовано: 24.03.2014 12:37:26
So what? Keep in mind that this was a hint on that the topic has been shifted to the bug tracking system. Thanks for the hint with the comma.
#26 Опубликовано: 24.03.2014 16:55:02
2 335 сообщений из 4 031 понравились пользователям.
Группа: Super Administrator
Thank you! This issue is pretty critical. Will handle it asap.
All bugs I will manage using http://smath.info/bts/, so Features/Bugs subforums is redundant now.
ioan92 24.03.2014 18:11:00
