Is SMath no Longer Freeware for Organizations? ANSWER: IT IS!
Is SMath no Longer Freeware for Organizations? ANSWER: IT IS! - Discussion of SMath Licensing - Сообщения
#41 Опубликовано: 21.09.2022 11:42:12
Hildebrando Pereira dos Santos Junior
2 сообщений из 21 понравились пользователям.
Dont forget the "Details" screen.
#42 Опубликовано: 21.09.2022 11:47:59
Thank you uni; it is beneficial to understanding the driving cause for the changes in the EULA.
However, I believe rex he was making a comment to the effect:
  • The Pricing https://en.smath.com/view/SMathStudio/pricing; features the "can be used for commercial purposes"
  • Per https://en.smath.com/view/SMathStudio/license; "SMath Studio is free for private use. The capabilities of the program and its scope of application can be expanded by purchasing additional services associated with a personal account;"
  • per the EULA (english) installed/accepted via the actual install:, "SMath Studio is free for private use. The capabilities of the program and its scope of application can be expanded by purchasing additional services associated with a personal account;".
If we want to use SMath for commercial purposes, we are left with the dilemma that the actual EULA only mentions private use (and infers commercial/educational uses might not be authorized). It would be nice if commercial use, and the limitations thereof, are included in the EULA.
Yours Sincerely,
-Kenny Lemens, P.E.
Hi Andrey!
Do you change your decision in the New version 1.0?
Hello.
For non-russian users nothing changed.
Russian license a bit changed to face that program is free for private use only. For others program can be used for free for any purposes, including commercial - as it always was.
Hi Andrey, thanks for letting me use this wonderful software for many years...
I just read all the discussions in here, but I found the comments in the pricing & License is not the same:
This may lead misunderstanding if someone only check the License page...
Hi Kenny. As far as I understand, to be able to use it for commercial purposes (and I guess academics too) you only need to register it, and not install it with that account on more than 5 computers, as can be read in the green option in https://en.smath.com/view/SMathStudio/pricing
What I do assume is that in each of these installations you need to log in so as not to violate the conditions of your purchase, free but with registration needed.
That is, if you use it without logging in, you can still use it for personal, but not for commercial purposes.
I think it's not, when we log in the details show private use... Where I work, I had problems because of the license agreement. The IT department demanded that I remove Smath Studio.
For now, the only solution is still using any version before 7822.
Alvaro 21.09.2022 13:16:00
#43 Опубликовано: 21.09.2022 13:17:20
1 124 сообщений из 1 796 понравились пользователям.
Hi Hildebrando. I see, you're right.
#44 Опубликовано: 26.07.2023 11:23:33
Glenn Thierens
Glenn Thierens
0 сообщений из 7 понравились пользователям.
Hi Andrey!
Hello.
Hello Andrey,
Could you please shed some light on this? There is another topic as well on this: https://en.smath.com/forum/yaf_postst23565_PDF-watermark.aspx
I experienced as well that I often have to login again to get rid of the watermark. Sometimes, it shows my name in green as if I am logged in and the watermark still persists. In this case, rebooting temporarily fixes the problem.
Is this a bug or do you intend to limit the free use of SMath for commercial purposes outside Russia? I can respect either answer, but some clarity would be helpful to help us make motivated decisions on the use of SMath in the future.
Best regards,
#45 Опубликовано: 28.06.2024 04:16:16
Daniel Jackson
Daniel Jackson
1 сообщений из 17 понравились пользователям.
PLEASE make the Modeller Region plugin available for free immediately! Either that or make it so that if a person installed some plugin(s) before the license changed, they can keep updating/using them without needing a subscription. Better yet, make all plugins free again, and offer a perpetual license option so that people only have to pay once for the license. Some people can't afford subscriptions. I hate it that I can't update/use certain plugins without upgrading.
#46 Опубликовано: 28.06.2024 23:53:47
Arie
Arie
Have you tried offline installation?
https://wiki.smath.com/en-US/Plugins
Most plugins are still free to use/update. They just don't auto update through the app without a paid license.
#47 Опубликовано: 26.09.2024 01:55:24
Daniel Jackson
Daniel Jackson
I tried the offline installation steps to update, and when I tried to download the zip files, I got a 402 Payment Required error (same thing happened when I tried to download them via wget). Can someone please tell me how to update them for free? The plugins I'm trying to download are Modeller Region and XMCD Files Plugin, and I want to update them without upgrading my account! Please make them free for all users immediately! I believe that every last plugin should be available for free to every single user, whether they have a free or paid plan, and that auto-updates of said plugins should also be available for free users. Also, I can't get the Script Region plugin to work: The system cannot find the file specified. (Exception from HRESULT: 0x80070002).
Also, why can't I create polls? Is that the norm for users around here?
