RadioButtonList Region
RadioButtonList Region - adds RadioButtonList controls to SMath Studio and SMath Viewer - Сообщения
#21 Опубликовано: 30.10.2018 08:00:32
126 сообщений из 341 понравились пользователям.
Davide, when strings are used, misalignment occurs in Smath0.99 build 6873 (win7)
[albumimg]1525[/albumimg]
Davide Carpi 30.10.2018 11:17:00
#22 Опубликовано: 30.10.2018 11:17:40
1 441 сообщений из 2 932 понравились пользователям.
Confirmed, thank you.
Mark R Harris 28.05.2022 02:02:00
#23 Опубликовано: 02.11.2018 10:09:31
Fixed, plugin updated.
sergio 02.11.2018 11:01:00
#24 Опубликовано: 24.06.2020 08:08:44
PLUGIN UPDATED SMath Studio 0.99.7251 and later
  • Enhanced alignments of embedded MathRegions;
sergio 24.06.2020 13:48:00, Mark R Harris 28.05.2022 02:02:00
#25 Опубликовано: 29.07.2022 15:02:27
Prmtv
Prmtv
0 сообщений из 49 понравились пользователям.
PLEASE REPORT HERE ANY ISSUE
Hello. I found out an interesting feature (my post https://en.smath.com/forum/yaf_postst23152_Data-selection.aspx)
In short: For correct display in SMath Viewer, plugin must be used first among others plugins from "Controls". If it is not used first or used two or more in a row, it will display incorrectly in SmathViewer.
#26 Опубликовано: 30.07.2022 06:17:12
Thank you, I'll check it ASAP.
Mark R Harris 31.07.2022 23:55:00
#27 Опубликовано: 04.03.2024 06:06:10
Jason McCool
Jason McCool
9 сообщений из 78 понравились пользователям.
After installing the latest version of SMath (1.1 build 8763), the radio button list region plugin is disabled (along with several others). I've used this one a fair bit over the years... any chance of it being updated?
