RC: SMath Studio 0.97.5301 (07 July 2014)
RC: SMath Studio 0.97.5301 (07 July 2014) - Сообщения
#21 Опубликовано: 19.07.2014 04:23:19
This is a decimal separator issue. If you use the period as dec sep, then units with subscripts display correctly (SS-173)
#22 Опубликовано: 19.07.2014 05:46:57
LitvincevYV
LitvincevYV
1 сообщений из 7 понравились пользователям.
thanks
#23 Опубликовано: 25.07.2014 18:39:00
Ryan Freund
Ryan Freund
20 сообщений из 339 понравились пользователям.
I seem to have a problem with "Areas"
Try this:
1. Type Text (call this top text)
2. Insert Area below text
3. Type in area (call this "in area text")
4. close area (note that this does not include "top text")
5. Open area
6. Move top area line above the "Top Text" so that it is not inside the area
7. Close area
8. Notice that the "top text does not close into the area"
9. However, Save the file, close SMath and restart the program. Open the file and all is fine.
Anyone else has this issue?
#24 Опубликовано: 26.07.2014 01:58:47
There are already known problems with area region (see this in Bugs SS-171 for instance). Moving area handlers is an especially risky operation. SMath can crash easily than.
