how to know the name of the variable - Сообщения
Forum Var name.sm (13,9 КиБ) скачан 1261 раз(а).
Вот так можно решить задачу при помощи компонента Скрипт.
![2017-03-05 20-38-03 SMath Studio - [Script. Kross example 1.sm ].png](/ru-RU/files/Download/PV2XNT/2017-03-05-20-38-03-SMath-Studio---[Script.-Kross-example-1.sm-].png)
Script. Kross example 1.sm (6,33 КиБ) скачан 1249 раз(а).
Script. Kross example 1.pdf (18,03 КиБ) скачан 786 раз(а).
var defs = Enumerable.Range( 0, store.Count ).Select( n => store[n] ).ToList();
var args = ( Entry.Create( terms ) ).Items.ToList();
var vars = args.Take(4).Select( x => new Entry( "\"" + x.Text + "\"" ) ).ToList();
var vals = args.Take(4).ToList();
var desc = args.Take(4)
.Select( x => defs.Find( d => d.Name.Equals( x.Text ) ).Description )
.Select( x => new Entry( "\"" + x + "\"" ) ).ToList();
var rows = new Entry( "4" );
var cols = new Entry( "3" );
var mat = new Entry( "mat", TermType.Function, new Entry[]
vars[0], vals[0], desc[0],
vars[1], vals[1], desc[1],
vars[2], vals[2], desc[2],
vars[3], vals[3], desc[3],
rows, cols
store.AddDefinition( args[4].Text, new Term[0], mat );
Davide Carpi 05.03.2017 20:12:00
Is there access to some list of definitions in the sheet? The script example seems to reqire explicit specification, which variables are to be processed. Could I just ask to export everything (excluding pre-defined names)?
If specification of the variables is acceptable, then the matrix can be created relying on math regions only.
export.sm (6,2 КиБ) скачан 1277 раз(а).
![2017-03-05 18_00_56-SMath Studio 0.98.6179 - [Script.%20Kross%20example%201.sm_].png](/ru-RU/files/Download/GQZK4L/2017-03-05-18_00_56-SMath-Studio-0.98.6179---[Script.%20Kross%20example%201.sm_].png)
Вячеслав Мезенцев 05.03.2017 14:14:00
WroteIs there access to some list of definitions in the sheet? The script example seems to reqire explicit specification, which variables are to be processed. Could I just ask to export everything (excluding pre-defined names)?
Yes, the first line do it.
This means: get all enabled definitions.
How to check this.
.ToList();
defs.ForEach( d => store.TraceData( d.ToString() ) );
![2017-03-05 22-21-48 SMath Studio - [List1 ].png](/ru-RU/files/Download/3TLzsX/2017-03-05-22-21-48-SMath-Studio---[List1-].png)
Martin Kraska 05.03.2017 14:32:00
I just downloaded the script region and pasted the code above into it and set language to C#.
This gives the error message in the output window:
Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
(system can't find the file)
SMath Studio: SMath Studio Desktop 0.98.6179.21440, portable, x86
OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (Windows 7 Professional , x64)
Screen: 1920x1080 px, 96x96 dpi
Localization: separator=; decimal symbol=; system decimal symbol=; language=GER
Frameworks: CLR 2.0.50727.5485
installed versions:
v2.0.50727 2.0.50727.5420 SP2
v3.0 3.0.30729.5420 SP2
v3.5 3.5.30729.5420 SP1
v4
Client 4.6.01055
Full 4.6.01055
v4.0
Client 4.0.0.0
installed versions:
v4
Client 4.6.01055
Full 4.6.01055
v4.0
Client 4.0.0.0
Try to remove it manually and update again (20ad815b-bc5e-487d-9258-57fde2ac6de8).
For 0.98.6179 last version is 0.1.6273.2204.
I deleted the dir and re-installed from extension manager (I did this just some hours ago, thus if the online gallery didn't change, then this didn't change anything locally).
There is a file LinqBridge.dll, yet the log file says
05.03.2017 19:30:58 [INFO ] Script Region, version 0.1.6273.2204, Sonntag, 5. März 2017 01:13:28
05.03.2017 19:31:28 [ERROR] Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
It says that LinqBridge or a dependence of it was not found.
Same message in the output window.
I think I found the problem. Plugin updated, please try again.
Sorry, didn't solve the problem. This is what the log says:
05.03.2017 20:05:57 [INFO ] Script Region, version 0.1.6273.19487, Sonntag, 5. März 2017 10:49:34
05.03.2017 20:06:20 [ERROR] Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
I forgot to replace Tech.CodeGeneration.dll. Plugin updated, try again.
05.03.2017 20:31:31 [INFO ] Script Region, version 0.1.6273.20457, Sonntag, 5. März 2017 11:21:54
05.03.2017 20:31:54 [ERROR] Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
Wrote05.03.2017 20:31:31 [INFO ] Script Region, version 0.1.6273.20457, Sonntag, 5. März 2017 11:21:54
Only portable version not working or both?
Good point, installer version works. But installer version is a bad place for experiments.
Ok, I need portable version. How I can get it? This link not working for me.
Currently the link is broken. Unpacking the linux version to some directory and placing an empty file "portable.version" in the install dir is a workaround (or better: the official way).
Well, I reproduced the problem. It is much harder to fix than I thought before (I don't know why it is happening for portable version).
Сontinue in this topic.
Something close to your request (input must be provided with strings, output is automated and issues reported in trace window)
name+value+description.sm (7,5 КиБ) скачан 1284 раз(а).
![2017-03-17 16_41_00-SMath Studio - [name+value+description.sm_].png](/ru-RU/files/Download/CYXgmr/2017-03-17-16_41_00-SMath-Studio---[name+value+description.sm_].png)
