Help with continuousfunctions
Help with continuousfunctions - heating and cooling curves - Сообщения
#21 Опубликовано: 24.02.2016 09:22:04
mtothaz
mtothaz
Hi Jean,
ok this looks different... I will see how I can implement this into my case.
Thank you for your help the whole time!
best regards
Mark
#22 Опубликовано: 24.02.2016 17:25:41
Mark,
This is purely classroom demo. If you have to control something,
digital controllers are very cheap. Otherwise you would spend
your life re-inventing the wheel. Digital controllers don't
work work as simply as that unless ON-OFF.
#23 Опубликовано: 09.03.2016 14:03:14
mtothaz
mtothaz
Thank you Jean for your help all the time, I could manage to deal with a 90% solution for my work!
