UPDATED: SMath Studio 0.98.6593 (19 January 2018)
UPDATED: SMath Studio 0.98.6593 (19 January 2018) - Сообщения
#21 Опубликовано: 17.01.2018 17:35:03
Andrey, remarkable pace of updates ;-)
You might consider updating the range buttons in the side panel to reflect the brackets
Yet this would be less important if the GUI would accept double period as shortcut for range input. I.e. typing 1..3 is expanded into range(1,3). Range(3) would then be triggered by either inserting arg sep behind the second number (to be consistent for those who know about range() or behind the first number (which would be intuitive from what the operator formatting looks lile).
#22 Опубликовано: 17.01.2018 17:45:36
Yes Martin: very nice !
Now, you committed yourself for more testing, is it .
First of all I am committed to update the pdf Handbuch and the bilingual Getting Started tutorial. The interactive handbook still seems too inconvenient to access for newcomers, therefore it's maintenance is further down in priority.
Jean, you might consider organizing your examples into a hierarchical structure with index pages and plug that into the interactive handbook or generate a separate example manual on your own. This would make it much easier to find all the treasures...
But to be honest, maintenance of such documents isn't fun. You work hard to find and document clever workarounds for bugs and missing features just to find out that with each release you can scrap some portions of the stuff.
It is: The better the software gets, the less a handbook is needed.
#23 Опубликовано: 19.01.2018 12:12:44
2 342 сообщений из 4 041 понравились пользователям.
Группа: Super Administrator
New version of SMath Studio 0.98.6593 released. Topic updated.
Serg 22.01.2018 08:41:00, NDTM Amarasekera 19.01.2018 13:25:00, frapuano 19.01.2018 14:27:00
