Forum Interface
Forum Interface - A lot changed - Сообщения
#21 Опубликовано: 22.08.2025 20:42:40
2 335 сообщений из 4 031 понравились пользователям.
Группа: Super Administrator
Thank you, Davide!
We will fix these issues shortly.
Themes support was enabled today via a regular web update on the root server. The development of this feature is ongoing, and we'll continue to refine and improve it in the coming days.
For now, the light theme is enabled by default. Once the work is complete, the system theme will become the default option.
Davide Carpi 22.08.2025 20:44:56, francesco rapuano 23.08.2025 16:27:09
#22 Опубликовано: 27.08.2025 00:00:05
I think some icons should be adapted to have more contrast, though (f e. the ones in the post editor and the ones on top of the single posts). The quote box has some issues too.
Corrected.
Davide Carpi 28.08.2025 07:47:18
#23 Опубликовано: 28.08.2025 07:47:04
1 442 сообщений из 2 935 понравились пользователям.
Quote region is fine now, but icons seems vanished?
#24 Опубликовано: 28.08.2025 10:08:38
Davide, can't confirm. Works ok on Chromium based browsers
#25 Опубликовано: 28.08.2025 10:14:32
Can confirm, seems a browser engine issue. On chromium browsers works just fine, on firefox based browsers (both desktop and mobile) icons are not visible.
Andrey Ivashov 28.08.2025 10:15:44
#26 Опубликовано: 28.08.2025 10:15:09
I see, issue is in Firefox... Ok, will handle.
Davide Carpi 28.08.2025 15:41:05
#27 Опубликовано: 30.08.2025 09:44:47
Finally fixed. Thank you for reporting this issue!
Davide Carpi 30.08.2025 09:54:14, ioan92 30.08.2025 10:41:55
