Page History: Graphs
Page Revision: 2014/03/08 02:58
How to add an empty graph
You can add a 2D/3D Graph from the
Insert item in the menu bar:
Insert > Plot > 2D / 3D
Plot equations
NOTE: variables are case sensitive (x is different from X)
Directly from the plot window
Plot matrices
You can plot figures from
Multiple plots
toolbox:
Special plots (words, points, colors...)
You can plot words or characters (strings) on your 2D graphs;
- Special characters (case sensitive) have position fixed on center on the given coordinates: + . * o x;
- Words, phrases or non-special characters have top-left corner of (virtual) textbox fixed on the given coordinates;
- Size and color columns are not required (so you can use a 3, 4 or 5 columns matrix);
- Values of size column are absolute, so the resize action does not affect the appearance of special plots;
- Many colors are allowed, using web format (like "#6699CC" or "#FF6699CC") or by name; here is a complete list of possible colors:
honeydew, hotpink,
indianred, indigo, ivory,
khaki,
navajowhite, navy,
red, rosybrown, royalblue,
violet,
wheat, white, whitesmoke,
yellow, yellowgreen
NOTE: You can use darkblue, DarkBlue, Dark Blue (recommended), DARKBLUE, D a R k B l U e ant etc...
It is possible to plot a single column vector using as index the x variable.
In the plot any x value will be rounded and, if possible, the corresponding vector element will be used as y value:
A dedicated plot palette allow some operations on the graph.
Clicking with the right mouse button on the graph appears a context menu that contains other options.
