Page History: Graphs
Page Revision: 2012/04/27 18:49
How to add an empty graph
Insert > Plot > 2D / 3D
- A 2D Graph can be added directly typing '@'
Plot equations
- 'x' and/or 'y' for 3D graphs
Directly from the plot window
Plot matrices
You can plot figures from
Multiple plots
You can plot multiple equations/matrices on the same graph using the '
Multiple values' item
Each "value" will be colored differently (cycling between 6 colours: blue,red,green,magenta,orange and brown)
Animated plots
See
animationsPlot handling
under constructionReferences
under constructionHints
Zooming is done with the zoom tool. If you roll your mouse wheel it zooms both axes together. If you hold 'control' at the same time it just zooms the vertical axis, and if you use 'shift' and the mouse wheel it zooms the horizontal axis.
Plot more than one curve by using the
Equation systems button on the
Functions toolbox
Examples of 2D & 3D graphs v0.85(pdf) Animations
