Page History: description
Page Revision: 2012/08/08 03:37
description(
parameter) returns description text of the definition
parameter using current language.
parameter can be a variable or a built-in function/constant/unit.
Syntax
if
parameter is a built-in function, unit or constant,
description() returns the built-in description.
if
parameter is a user-defined function or a variable,
description() returns the user-defined description.
if the user-defined description have multiple lines,
description() returns the description in a single line string.
History
See also
References
GetFile.aspx?File=description%2fdescription%20tutorial.zip|description tutorial.zip]
