Page History: trace
« Older Revision - Back to Page History - Current Revision
Page Revision: 2012/08/13 15:13
trace(var#1,var#2,...,var#n) trace evaluations through the Output window.
Returns a string containing the value of the arguments with output order and surrounding text specified by first argument. Specifying of the first text argument is optional.
trace(...) it's a function introduced to help users with script's debug.
Syntax
if var#1 is not a text, trace(...) returns comma separated values
example
if var#1 is a text, trace(...) returns the string (no other values)
example
if var#1 is a trace-formatted text, trace(...) returns a string according with var#1 pattern.
to show variable values with custom text/order you must insert into curly brackets the trace() variable position index;
variable position index is 0 for var#2, 1 for var#3, 2 for var#4, etc...
example
NOTE: curly brackets can be added typing "shift" + "[" for "{" and "shift" + "]" for "}"
trace(...) output can force evalutation, placing before the position index:
  • S: for symbolic evalutation
  • N: for numeric evalutation
example
Usage
trace() can be used:
  • directly, like a common function requiring numerical (=) or symbolical (→) evalutation
  • directly, inside for loops (at least one operation must be performed inside the loop)
  • directly, inside line() (at least one operation must be performed inside the line())
History
  • SMath 0.91 (stable): first relase
See also
References
