Units
Modified: 2014/07/07 23:44 by w3b5urf3r - Categorized as: English
Redirected from: Units of measurement
SMath Studio can handle units; there's a large list of built-in units available for the most common applications that could be easily extended by the user.
Units are represented with an italic blue-colored font.
unit example
Edit
Insert a unit
To insert a unit, press the apostrophe (') and then digit the unit name; the placeholder shape will change and the dynamic assistance box can help you showing the built-in units (mouse pointer double-click or press the TAB key to insert the selected unit in the formula).
insert unit
Alternatively you can add a built-in unit by the units window (CTRL+W or menu "Insert" > "Unit..."), where you can easily find the unit by name or by family.
units window
output unit
NOTE: the multiplication sign for units is hidden by default, so units like kN*m are shown kN m; to avoid errors the right way to type the unit is 'kN*'m, not 'kNm.
Edit
Custom units
You may define/override an unit inside the sheet (simplest way) or handling the Units.xml file (update).
units define
Edit
Units language
if you have not yet implemented localized units in your country leave a comment here: localization differences
From the menu "Tools" > "Options..." you can change the units language.
units language
The unit localization changes the way in which is written the unit of measurement.
units localization
Edit
Units description
Both built-in and custom unit description can be retrieved as a string using the description() function; description's language depends on Interface language.
units language
Edit
Known issues
to inform the developers about issues you found out use the forum: bugs&problems
Not all built-in functions work with units; to work with these functions divide the argument for the expected unit and multiply the result by the same unit.
built-in functions
The 0 value has no units. If you want a unit as output even when the result can be null, set the unit in the right placeholder.
null output
Be careful in handling relative and absolute temperature units; there's an open discussion here. THIS IS SOLVED IN NIGHTLY BUILDS, SEE SMath 0.97.5301 or later
null output
Edit
History
  • SMath 0.87.3719 (Beta): first relase
  • SMath 0.88 (Stable): first stable relase
  • SMath 0.90 (Stable): translatable units implemented
  • SMath 0.97.5280 (Nightly build): Units.xml changes
  • SMath 0.97.5301 (Nightly build): Change units ΔC, ΔF and ΔRe added to package
Edit
See also
Edit
References
  • Introduction to SMath Studio 0.88 - page 15, PDF
  • Video examples of calculations with units for hydraulics (G.Urroz) - See Part 2 SMath Studio
  • Crib Sheet for SMath Studio 0.95 - PDF
  • Crib Sheet for SMath Studio 0.90 - PDF
  • Crib Sheet for SMath Studio 0.89 - PDF
  • Crib Sheet for SMath Studio 0.88 - PDF
  • Custom units examples - sm
  • Unit.xml editing - SMath forum
