Page History: Examples
Page Revision: 2010/05/14 06:09
Engineering
  • CEE Fluid Mechanics Test 1 (G.Urroz): | Prob 1 pdf zip | Prob 2 pdf zip | Prob 3 pdf zip |
  • CEE Fluid Mechanics Test 2 (G.Urroz) pdf zip
  • CEE Fluid Mechanics Test 3 (G.Urroz) pdf zip
  • Dynamics (G.Urroz) Test 1: pdf zip | Test 2: pdf zip | Test 3: pdf zip
  • Ramp Design - testing for max allowable moment and deflection pdf zip
Numerical methods
Statistics
  • Normal distribution pdf zip
  • F-distribution pdf zip
