Page History: Examples
Page Revision: 2011/02/09 12:37
Engineering
  • CEE Fluid Mechanics Test 1 (G.Urroz): | Prob 1 pdf zip | Prob 2 pdf zip | Prob 3 pdf zip |
  • CEE Fluid Mechanics Test 2 (G.Urroz) pdf zip
  • CEE Fluid Mechanics Test 3 (G.Urroz) pdf zip
  • Engine Heat Rejection Calcs - good example of working with relative temperature differences (US Customary Units) pdf zip
Civil Engineering Hydraulics
Numerical methods
Statistics
  • Normal distribution pdf zip
  • F-distribution pdf zip
