Page History: Keyboard shortcuts
Page Revision: 2009/09/18 01:03
Here is an incomplete list of shortcuts built-in into SMath Studio:
Inserting
Ctrl+M - Insert Matrix
Ctrl+E - Insert Function
Ctrl+T - Insert blank Image
Ctrl+Shift+P - Insert Pi constant (3.1415...)
Ctrl+Shift+Z - Insert Infinity
\ - Insert square root
Ctrl+\ - Insert n-th root
[ - Insert el() function - subscript
Ctrl+= - Insert Boolean "equal to"
Ctrl+1 - Insert Matrix transpose
Ctrl+g - After a character gives it in Greek (Symbol palette)
Calculating
Ctrl+. - Symbolic calculation of the equation
Editing
Ctrl+Z - Undo changes
Ctrl+Y - Redo changes
Ctrl+X - Cut
Ctrl+C - Copy
Ctrl+V - Paste
Ctrl+A - Select all page controls / Select all inside the control (depends on cursor position)
Standard
Ctrl+N - Create a new page
Ctrl+F4 - Close current page
Ctrl+P - Print current page
Ctrl+O - Show open file dialog
Ctrl+S - Save current page
