Page History: Graphs
Page Revision: 2012/04/29 15:26
How to add an empty graph
You can add a 2D/3D Graph from the
Insert item in the menu bar:
Insert > Plot > 2D / 3D
![add new graph](GetFile.aspx?File=graphs/wiki-01-01.png)
![empty graphs](GetFile.aspx?File=graphs/wiki-01-02.png)
Plot equations
NOTE: variables are case sensitive (x is different from X)
Directly from the plot window
![single equation - direct input](GetFile.aspx?File=graphs/wiki-02-01.png)
![single equation - indirect input](GetFile.aspx?File=graphs/wiki-02-02.png)
Plot matrices
You can plot figures from
![single equation - matrices](GetFile.aspx?File=graphs/wiki-03-01.png)
Multiple plots
toolbox:
![multiple equations/matrices - example](GetFile.aspx?File=graphs/wiki-04-01.png)
![multiple equations/matrices - colours](GetFile.aspx?File=graphs/wiki-04-02.png)
![special plots](GetFile.aspx?File=graphs/wiki-05-01.png)
- Special characters (case sensitive) have position fixed on center on the given coordinates: + . * o x;
- Words, phrases or non-special characters have top-left corner of (virtual) textbox fixed on the given coordinates;
- Many colors are allowed; here is a complete list of possible colors (spaces and upper case letters are not matter):
honeydew, hotpink,
indianred, indigo, ivory,
khaki,
navajowhite, navy,
red, rosybrown, royalblue,
violet,
wheat, white, whitesmoke,
yellow, yellowgreen
NOTE(1): You can use darkblue, DarkBlue, Dark Blue (recommended), DARKBLUE, D a R k B l U e ant etc...
NOTE(2): You can use number instead of color name as well.
- first pair is opacity;
There are snippets to make easy this conversion (see References).
Note that because of the maximum 32-bit integer is 2147483647 (0xFFFFFFFF/2) and FF00FF00 = 4278255360 (i.e. greater then the max. integer),
then Green is FF00FF00-0xFFFFFFFF-1=-16711936.
Animated plots
See animations
![animated plot](GetFile.aspx?File=graphs/wiki-06-01.gif)
Plot handling
under construction
![plot handling - toolbox](GetFile.aspx?File=graphs/wiki-07-01.png)
![plot handling - mouse](GetFile.aspx?File=graphs/wiki-07-02.png)
Zooming is done with the zoom tool. If you roll your mouse wheel it zooms both axes together. If you hold 'control' at the same time it just zooms the vertical axis, and if you use 'shift' and the mouse wheel it zooms the horizontal axis.
See also
References
Tutorials and examples:
