Page History: IDEs and programming languages to use for developing plugins
Page Revision: 2010/06/05 09:38
IDEs and programming languages for Developing Smath Plugins
To develop plugins for Smath Studio you need to use an integrated development environment (IDE), which is just a fancy term for a software application that helps you create applications that may be used by Smath. The IDE may be used to program in your particular programming language of choice. However, the programming language you use must be able to utilize the Microsoft .NET Framework.
There are several possible choices that may be used for developing plugins for Smath Studio. (Note: Theoretically, the IDEs and languages mentioned here should all work, but have not all been tested. Also, this list is not complete and should be expanded.)
Programming Languages that may be used to develop plugins for Smath
C#
Visual Basic
F#
IronRuby
IronPython
Visual Studio Professional Editions
Visual Studio Express Editions
Iron Ruby
=== Iron Python===
