Page History: Graphs
Page Revision: 2013/04/16 12:20
How to add an empty graph
You can add a 2D/3D Graph from the
Insert item in the menu bar:
Insert > Plot > 2D / 3D
Plot equations
NOTE: variables are case sensitive (x is different from X)
Directly from the plot window
Plot matrices
You can plot figures from
Multiple plots
toolbox:
- Special characters (case sensitive) have position fixed on center on the given coordinates: + . * o x;
- Words, phrases or non-special characters have top-left corner of (virtual) textbox fixed on the given coordinates;
- Many colors are allowed, using web format (like #6699CC) or by name; here is a complete list of possible colors (spaces and upper case letters are not matter):
honeydew, hotpink,
indianred, indigo, ivory,
khaki,
navajowhite, navy,
red, rosybrown, royalblue,
violet,
wheat, white, whitesmoke,
yellow, yellowgreen
NOTE(1): You can use darkblue, DarkBlue, Dark Blue (recommended), DARKBLUE, D a R k B l U e ant etc...
NOTE(2): You can use number instead of color name as well.
- first pair is opacity;
There are snippets to make easy this conversion (see References).
Note that because of the maximum 32-bit integer is 2147483647 (0xFFFFFFFF/2) and FF00FF00 = 4278255360 (i.e. greater then the max. integer),
then Green is FF00FF00-0xFFFFFFFF-1=-16711936.
Animated plots
See animations
Plot domains
If you want to define a plot inside a specified domain you can follow two ways:
Using an if/else statement
NOTE: Any text (empty or not) or message from the error function will be ignored.
Using booleans as function parameters
NOTE: infinite values will be ignored.
Plot handling
under construction
Zooming is done with the zoom tool. If you roll your mouse wheel it zooms both axes together. If you hold 'control' at the same time it just zooms the vertical axis, and if you use 'shift' and the mouse wheel it zooms the horizontal axis.
History
- SMath 0.78 (stable): Added ability to Zoom graphs by mouse wheel;
- SMath 0.82.3477 (stable): Added ability to plot multiple graphs on the canvas (2D & 3D): multiple Graphs can be specified by functions or/and points at the same time; +/- and -/+ operators also can be used; 2D Graphs now can be inserted into the page by pressing "@" symbol;
- SMath 0.85 (stable): Added ability to separately change axis scale factor on 2D graphs using Ctrl/Shift + Mouse Wheel;
- SMath 0.89.8 (Beta): Added ability to draw text and special characters on the 2D Plot Control canvas;
- SMath 0.90 (stable): Graph animation implemented; Plot 2D and Plot 3D buttons removed from the math toolbar panel;
- SMath 0.94 (stable): Added support for colors specifying for the special objects and strings into the Plot Region using web format (like #6699CC);
See also
References
Tutorials and examples:
Others:
