Page History: IDEs and programming languages to use for developing plugins
Page Revision: 2012/04/04 11:14
IDEs and programming languages for Developing Smath Plugins
To develop plugins for Smath Studio you can use an integrated development environment (IDE), which is just a fancy term for a software application that helps you create applications that may be used by Smath. The IDE may be used to create plugins in the particular programming language of your choice. However, the programming language you use must be able to utilize the Microsoft .NET Framework.
There are several possible choices that may be used for developing plugins for Smath Studio. (Note: Theoretically, the IDEs and languages mentioned here should all work, but they have not all been tested with Smath. Also, this list is not exhaustive and may be expanded.)
Programming Languages that may be used to develop plugins for Smath
C# | Website
Visual Basic | Website
F# | Website
IronPython | Website
IronRuby | Website
IDEs that may be used for developing plugins for Smath
Visual Studio Professional Editions
Website
Visual Studio Express Editions
Website
SharpDevelop
Runs on Windows only.  Website
MonoDevelop
Runs on Linux, MacOS X, and Windows.  Website
Wing IDE
For development in Python; runs on Linux, MacOS X, and Windows.  Website
SMath plugins must run on .NET (or Mono); Python plugins are no exception.  The currently available Python implementation for .NET and Mono is IronPython (see it in the list of programming languages above).
As of 2012-Apr-03, Wing IDE's Supported OSes and Python Versions page says (emphasis added):
Wing IDE's debugger currently does not support IronPython, Jython, PyPy or other Python implementations.  However, the editor and most of the other tools in Wing IDE can be used with any of these, if a matching version of CPython is available on your system.
