Page History: Graphs
Page Revision: 2013/07/10 07:48
How to add an empty graph
You can add a 2D/3D Graph from the
Insert item in the menu bar:
Insert > Plot > 2D / 3D
Plot equations
NOTE: variables are case sensitive (x is different from X)
Directly from the plot window
Plot matrices
You can plot figures from
Multiple plots
toolbox:
Special plots (words, points, colors...)
You can plot words or characters (strings) on your 2D graphs;
- Special characters (case sensitive) have position fixed on center on the given coordinates: + . * o x;
- Words, phrases or non-special characters have top-left corner of (virtual) textbox fixed on the given coordinates;
- Size and color columns are not required (so you can use a 3, 4 or 5 columns matrix);
- Values of size column are absolute, so the resize action does not affect the appearance of special plots;
- Many colors are allowed, using web format (like "#6699CC" or "#FF6699CC") or by name; here is a complete list of possible colors:
honeydew, hotpink,
indianred, indigo, ivory,
khaki,
navajowhite, navy,
red, rosybrown, royalblue,
violet,
wheat, white, whitesmoke,
yellow, yellowgreen
NOTE: You can use darkblue, DarkBlue, Dark Blue (recommended), DARKBLUE, D a R k B l U e ant etc...
NOTE: web colors are allowed both in hexadecimal RGB ("#RRGGBB") or hexadecimal aRGB ("#aaRRGGBB") format.
NOTE: You can use number instead of color name or web-color.
- first pair is opacity;
There are snippets to make easy this conversion (see References).
Note that because of the maximum 32-bit integer is 2147483647 (0xFFFFFFFF/2) and FF00FF00 = 4278255360 (i.e. greater then the max. integer),
then Green is FF00FF00-0xFFFFFFFF-1=-16711936.
Animated plots
See animations
Plot domains
If you want to define a plot inside a specified domain you can follow two ways:
Using an if/else statement
NOTE: Any text (empty or not) or message from the error function will be ignored.
Using booleans as function parameters
NOTE: infinite values will be ignored.
Plot handling
A dedicated plot palette allow some operations on the graph.
- Rotate: rotate 3D graphs (see Known issues).
- Scale: if you roll your mouse wheel it zooms both axes together. If you hold 'control' keyboard key (CTRL) at the same time it just zooms the vertical axis;
if you use the mouse wheel holding the 'shift' keyboard key (↑) it zooms the horizontal axis. This does not affect the appearance of special plots. - Move: drag the graph up or down, left or right; by default you can move the graph also by clicking and holding the left mouse button on the graph.
- Graph by points: show functions/straight lines as a set of points; could be useful to highlight discontinuities.
- Graph by lines: show functions/straight lines as lines (default).
- Refresh: restore the default view of the graph (axes origin moved to the graph center and zoom with default limits).
Clicking with the right mouse button on the graph appears a context menu that contains other options.
Known issues
| to inform the developers about issues you found out use the forum: bugs&problems |
There are several main known issues about graphs:
- grids are available in power of two only;
- axes limits are available by mouse wheel only;
- 3D plots loose alignments opening the worksheet;
- 3D coordinates are left-handed;
History
- SMath 0.78 (stable): Added ability to Zoom graphs by mouse wheel;
- SMath 0.82.3477 (stable): Added ability to plot multiple graphs on the canvas (2D & 3D): multiple Graphs can be specified by functions or/and points at the same time; +/- and -/+ operators also can be used; 2D Graphs now can be inserted into the page by pressing "@" symbol;
- SMath 0.85 (stable): Added ability to separately change axis scale factor on 2D graphs using Ctrl/Shift + Mouse Wheel;
- SMath 0.89.8 (Beta): Added ability to draw text and special characters on the 2D Plot Control canvas;
- SMath 0.90 (stable): Graph animation implemented; Plot 2D and Plot 3D buttons removed from the math toolbar panel;
- SMath 0.94 (stable): Added support for colors specifying for the special objects and strings into the Plot Region using web format (like "#6699CC");
See also
References
Tutorials and examples:
