Page History: diff
Page Revision: 2009/09/20 12:40
diff('expression','variable','order') - Differentiate.
If the 'order' is omitted, the first order derivative is asumed.
The function is used to perform symbolic or numeric derivatives. It can be inserted by typing diff( or from the Function palette under Derivative template (this is simpler).
Chose the Derivative template and insert in the 'variable' placeholder x and in the 'expression' placeholder x2. After that press CTRL+. (symbolic calculation). You should obtain this result:
deriv1
We could have defined the 'expression' f first in variabl x and y, for instance:
deriv1
and find the first derivatives over the variables (partial derivatives, actually):
deriv1
How to obtain the higher order derivatives? Press comma after the 'variable' and in the obtained placeholder insert the 'order' (integer). Here are the second derivatives:
deriv1
Here are mixed derivatives as well: deriv1
Instead of an expression we could have defined a function and repeat the procedure:
deriv1
Numerical derivatives are found at the given values. For instance:
deriv1
Very important SMath feature is ability to find the derivatives over the elements of a vector (matrix). Here is an example of finding Jacobi matrix and Jacobian:
deriv1
