Page History: TEST PAGE
Page Revision: 2013/01/10 13:34
PAGE UNDER CONSTRUCTION
How to make a plugin
Available plugins
here there is a list of compiled plugins; more plugins can be found on the SMath VisualSVN server
BUILT-IN PLUGINS
NameAuthorsDescription and ContentsLast updateSMathDownload
Math RegionAndrey Ivashov
Extends SMath Studio with a Math Region. Provides an ability to work with math expressions inside the Worksheet.-All versionsBuilt-in plugin
HTML ExportAndrey Ivashov
Save to HTML files type support plugin for SMath Studio.-All versionsBuilt-in plugin
Export to imageAndrey Ivashov
Extends SMath Studio with ability to export the worksheet data as an image. Supports four different image formats.-All versionsBuilt-in plugin
Picture RegionAndrey Ivashov
Extends SMath Studio with a Picture Region. Provides an ability to work with Images inside the Worksheet.-All versionsBuilt-in plugin
Plot RegionAndrey Ivashov
Extends SMath Studio with a Plot Region. Provides an ability to work with graphs inside the Worksheet.-All versionsBuilt-in plugin
SMath Studio Files PluginAndrey Ivashov
Save and open SMath Studio files types support plugin for SMath Studio.-All versionsBuilt-in plugin
Special FunctionsAndrey Ivashov
Special Functions built-in plugin for SMath Studio.-All versionsBuilt-in plugin
Text RegionAndrey Ivashov
Extends SMath Studio with a Text Region. Provides an ability to work with Text inside the Worksheet.-All versionsBuilt-in plugin
XMCD Files PluginAndrey Ivashov
Save and open XMCD files type support plugin for SMath Studio.-All versionsBuilt-in plugin
Area RegionAndrey Ivashov
Extends SMath Studio with an Area Region. Provides an ability to work with collapsed areas inside the Worksheet.-All versionsBuilt-in plugin
PLUGINS MADE BY USERS
Project NameAuthorsDescription and ContentsLast updateSMathDownload
TeXFileTypeAndrey Ivashov, IVRSave to TeX files type support pluginApril 2012N.D.forum
Plot3DViacheslav N. Mezentsev3D plotting functionsNovember 2010N.D.forum
MapleWrapperViacheslav N. MezentsevAllows you to use Maple functions in SMath sheets (Maple required in your machine)October 2012N.D.forum
ODESolversViacheslav N. MezentsevOrdinary differential equation solverNovember 2010N.D.forum
DebuggerViacheslav N. MezentsevPlugin just for testing (mcadefi plugin must be installed first)November 2010N.D.forum
mcadefiViacheslav N. MezentsevMathcad EFI plugin - This plugin will help you to connect the old unmanaged code (numerical) to SMath StudioApril 2012N.D.forum
AlgLibViacheslav N. MezentsevPlugin based on ALGLIB library (cross-platform numerical analysis and data processing library).November 2010N.D.forum
FIRFilterDesignViacheslav N. MezentsevMathcad remez clone July 2011N.D.forum
NonlinearSolversDavide CarpiA collection of root-finding methods and optimization algorithms (beta version require customFunctions plugin)December 2012≥ 0.95.4594forum
StatisticalToolsDavide CarpiA collection of statistical tools (Sample Estimators, Probability Density Functions, Cumulative Density Functions, Quantile functions, Generators of Random Numbers and other Tools)December 2012≥ 0.95.4594forum
DataExchangeDavide CarpiPlugin to export data to CSV files and to import and export data from/to ODS spreadsheetsDecember 2012≥ 0.95.4594forum
customFunctionsDavide CarpiGeneral purpose functionsDecember 2012≥ 0.95.4594forum
Known issues
to inform the developers about issues you found out use the forum: SMath forum
SMath's development can make a plugin made by an user outdated; if this happen, use the forum to inform the developers about it.
Actually there isn't detailed instructions for creating plugins, but this is in the works.
History
See also
References
