Page History: A Wiki Template
Page Revision: 2019/08/14 00:25
this page is intended to be a reference template to write "a good" wiki page, nothing else |
IN GREEN BOXES YOU CAN SEE HINTS AND SUGGESTIONS |
A brief description of this SMath Studio feature.
A menu should be used when there are many sections or wide sections; this help the user to have an idea of the entire page content in a single view. |
1st section
Lorem ipsum...
2nd section
Lorem ipsum...
3rd section
Lorem ipsum...
Known issues
to inform the developers about issues you found out use the forum: bugs&problems |
There are several main known issues about ...:
- 1st issue;
- 2nd issue;
- 3rd issue;
Only main issues should be written in the wiki; everything a user could reasonably think there should be but there is not. For everything else there's the forum :) |
History
- SMath 0.78 (stable): Added ....;
- SMath 0.89.8 (Beta): Added ....;
As for the issues, only main changes should be written in the wiki. |
But... why the history? If you share a worksheet, someone that use an old Smath Studio version could have some issue reading your file; |
moreover opening an old worksheet, something could be changed. In any case it's useful to see in a fast way what changes. |
See also
wuxiaworldReferences
