Page History: Units
Page Revision: 2013/01/04 00:30
SMath Studio can handle units; there's a large list of
built-in units available for the most common applications that could be easily extended by the user.
Units are represented with an | italic blue-colored font | . |
![unit example](GetFile.aspx?File=units%2funits_wiki_01.png)
Insert a unit
To insert a unit, press the apostrophe (
') and then digit the unit name; the placeholder shape will change and the dynamic assistance box can help you showing the built-in units (mouse pointer
double-click or press the
TAB key to insert the selected unit in the formula).
![insert unit](GetFile.aspx?File=units%2funits_wiki_02.gif)
Alternatively you can add a built-in unit by the units window (
CTRL+W or menu "
Insert" > "
Unit..."), where you can easily find the unit by name or by family.
![units window](GetFile.aspx?File=units%2funits_wiki_03.png)
![output unit](GetFile.aspx?File=units%2funits_wiki_04.gif)
NOTE: the multiplication sign for units is hidden by default, so units like
kN*m are shown
kN m; to avoid errors the right way to type the unit is
'kN*'m,
not 'kNm.
Custom units
You may define/override an unit inside the sheet (simplest way) or handling the
Units.xml file.
![units define](GetFile.aspx?File=units%2funits_wiki_05.png)
Units language
From the menu "
Tools" > "
Options..." you can change the units language.
![units language](GetFile.aspx?File=units%2funits_wiki_06.png)
The unit localization changes the way in which is written the unit of measurement.
![units localization](GetFile.aspx?File=units%2funits_wiki_06_B.png)
Unit description
The built-in unit description can be retrieved as a string using the
description() function.
![units language](GetFile.aspx?File=units%2funits_wiki_07.png)
Known issues
to inform the developers about issues you found out use the forum: bugs&problems |
Not all built-in functions work with units; to work with these functions divide the argument for the expected unit and multiply the result by the same unit.
![built-in functions](GetFile.aspx?File=units%2funits_wiki_08.png)
The 0 value have no units. If you want an unit as output even when the result can be null, set the unit in the right placeholder.
Be careful in handling relative and absolute temperature units; there's an open discussion
here.
History
- SMath 0.87.3719 (Beta): first relase
- SMath 0.88 (Stable): first stable relase
- SMath 0.90 (Stable): translatable units implemented
See also
References
- Introduction to SMath Studio 0.88 - page 15, PDF
- Video examples of calculations with units for hydraulics (G.Urroz) - See Part 2 SMath Studio
- Crib Sheet for SMath Studio 0.95 - PDF
- Crib Sheet for SMath Studio 0.90 - PDF
- Crib Sheet for SMath Studio 0.89 - PDF
- Crib Sheet for SMath Studio 0.88 - PDF
- Custom units examples - sm
- Unit.xml editing - SMath forum
