Page History: Viewer
Page Revision: 2013/05/04 01:26
PAGE UNDER CONSTRUCTION
Introduction
Viewer File Type plug-in which allows to create standalone executable files (*.exe) from your worksheets. SMath Viewer is an alternative GUI for SMath Studio.
The idea of SMath Viewer is that SMath Studio (as well as Mathcad) is a great application but sometimes it is too complex for regular engineer. Indeed, SMath Studio was initially created for composing worksheets of any complexity with many of built-in features introduced to simplify this process. As a result sometimes the end-users have to see too much excess information on the worksheets when it is just needed to read results of calculations in convenient way.
SMath Viewer plug-in creates applications to show only data users are needed to be seen. At the same time it works directly with SMath Studio worksheets, so no any significant actions required to reuse existing libraries of files. SMath Viewer is a distribution platform for worksheets created using SMath Studio.
So SMath Studio is an editor for worksheets and SMath Viewer is a reader.
Features
Lorem ipsum...
Usage
Lorem ipsum...
Known issues
to inform the developers about issues you found out use the forum: bugs&problems
This feature is early introduced, so may contains some issues.
History
  • SMath 0.96.4868: ViewerFileType built-in plugin added.
See also
References
