SMath Studio 0.96.4868 (30 May 2013)
SMath Studio 0.96.4868 (30 May 2013) - 消息
#61 已发布: 2013/10/10 08:24:16
arichardd
arichardd
0个赞,共2个帖子。
Thank you very much. Helped me a lot.
#62 已发布: 2013/10/11 11:28:43
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Any update on the official portable version? I have not seen any nightly builds or other communication. Thanks Martin for the unofficial version as a stop gap
#63 已发布: 2013/10/11 13:47:22
1,443个赞,共2,936个帖子。
显示剧透
#64 已发布: 2013/10/11 15:09:35
lpolkosnik
lpolkosnik
0个赞,共1个帖子。
Great program using install version would prefer portable, tried downloading but not autorized error
Keep up great work
Thanks,
Leon
#65 已发布: 2013/11/26 10:48:58
Luis
Luis
0个赞,共2个帖子。
I have a big problem: I installed the latest version of SMath and execute him shows me an error message: "Unable to find a version of the runtime to run this application". I have installed Windows XP with framework .net v4.0. On the other hand, I installed the same version on my Notebook with windows 7 home having built framework v4.0 .net and I have not had any problems. Could anyone tell me how to fix the problem in Windows XP?
#66 已发布: 2013/11/26 14:13:21
1,443个赞,共2,936个帖子。
SMath needs .NET framework 2.0.
from the Microsoft site (Version Compatibility in the .NET Framework)
引用
Compatibility and side-by-side execution
If you cannot find a suitable workaround for your issue, remember that the .NET Framework 4.5 runs side by side with versions 1.1, 2.0, and 3.5, and is an in-place update that replaces version 4. For apps that target versions 1.1, 2.0, and 3.5, you can install the appropriate version of the .NET Framework on the target machine to run the app in its best environment. For more information about side-by-side execution, see Side-by-Side Execution in the .NET Framework.
Here there is a list of embedded frameworks in MS OS:
What version of the .NET Framework is included in what version of the OS?
As you can see from the link above, you have to install the 2.0 Framework if your system is prior to Windows Vista
Moreover seems that users with Windows 8 or later needs to install the 3.5 framework
引用
It also includes the .NET Framework 3.5 SP1 as an OS component that is not installed by default. The .NET Framework 3.5 SP1 can be added or removed via the Programs and Features control panel.
#67 已发布: 2014/1/26 19:46:39
ramivei
ramivei
0个赞,共2个帖子。
it seems that the link to the latest portable version is not workimg
#68 已发布: 2014/1/27 05:03:59
1,362个赞,共2,276个帖子。
That is correct. You might try the inofficial portable version, see my signature.
#69 已发布: 2014/4/1 07:14:45
abelle
abelle
0个赞,共2个帖子。
The SMathStudioDesktop.0_96_4868.Portable.exe downoad link on this page gave server error 401 - Unauthorized: access is denied due to invalid credentials.
I think it is a dead link.
The portable versions are very nice for testing when you can't load software on the PC.
Thanks for your excellent software, which I don't use now, but can see it will be useful when I need it.
#70 已发布: 2014/4/1 11:05:45
1,362个赞,共2,276个帖子。
Just follow the link in my signature.
#71 已发布: 2014/5/27 04:58:28
olgapet
olgapet
0个赞,共1个帖子。
Get this error with the linux package:
gzip: stdin: invalid compressed data--crc error
tar: Child returned status 1
tar: Error is not recoverable: exiting now
_____________
врати, входни врати, врати
#72 已发布: 2014/5/31 10:50:27
popescu
popescu
0个赞,共1个帖子。
Heloo, I can not dowload last portable win version SMathStudioDesktop.0_96_4868.Portable.exe . tell me "401 - Unauthorized: Access is denied due to invalid credentials." ??
Please can you help me ?
Regards Popescu.
#73 已发布: 2014/5/31 13:39:24
Janusz
Janusz
7个赞,共48个帖子。
Hello Popescu,
Here:
Portable version.
you be able download the last portable version.
Janusz
