GNU Scientific Library (GSL)
GNU Scientific Library (GSL) - The GNU Scientific Library 2.x. - 消息
#21 已发布: 2021/12/20 16:11:14
1,558个赞,共1,868个帖子。
SMath Studio compatibility
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
#22 已发布: 2021/12/24 06:00:02
1,558个赞,共1,868个帖子。
Updated.
Changes:
- updated to GSL 2.7;
- gsl_version operand added;
- refactored.
#23 已发布: 2021/12/24 11:13:05
1,558个赞,共1,868个帖子。
Updated.
Changes:
- gsl_sf() function added (only airy supported);
- totally refactored.
The library has a huge number of functions, but it is very difficult to find a convenient method for calling them. I decided to try one method, calling special functions with one generic function and a combination of flags.
Click to enlarge
sergio 2021/12/24 12:20:00
#24 已发布: 2021/12/24 18:28:46
1,558个赞,共1,868个帖子。
SMath Studio compatibility Examples
Updated.
Changes:
- gsl_sf_airy() and gsl_sf_bessel() functions added;
- gsl_sf() function removed;
- examples added;
- refactored.
Click to enlarge Click to enlarge
Links:
1. Airy Functions and Derivatives
2. Bessel Functions
#25 已发布: 2022/2/1 09:27:54
DenisArd
DenisArd
0个赞,共1个帖子。
Плагин установлен и виден в SMath, но ни одна его функция не доступна. В чем может быть дело?
The plugin is installed and visible in SMath, but none of its functions are available. What can be wrong?
Windows 10 Home x64 21H1, SMathStudioDesktop portable (mono).
Upd: Разобрался. Нужен Microsoft Visual C++ 2015 Redistributable.
Understood. Requires Microsoft Visual C++ 2015 Redistributable.
https://www.microsoft.com/ru-ru/download/details.aspx?id=53840
#26 已发布: 2022/6/3 15:51:43
1,558个赞,共1,868个帖子。
SMath Studio compatibility gsl_interp.cpp
Updated.
Changes:
- gsl_interp() function added.
Click to enlarge
gsl_interp.sm (8.07 KiB)已下载 1929 次。
Links:
1. GSL Interpolation.
churichuro 2022/6/3 19:00:00
#27 已发布: 2022/6/5 13:32:31
1,558个赞,共1,868个帖子。
Resources
I finally figured out how to add a localization mechanism for function libraries. In the future, I will use it in all my plugins.
sergio 2022/6/6 06:46:00
#28 已发布: 2023/3/10 10:27:36
1,558个赞,共1,868个帖子。
Updated.
Changes:
- gsl_sf_erf(1), gsl_sf_erfc(1), gsl_sf_erf_Q(1), gsl_sf_erf_Z(1), gsl_sf_hazard(1) and gsl_sf_log_erfc(1) functions added.
2位用户喜欢此帖子
sergio 2023/3/10 17:10:00, Oscar Campo 2023/3/14 06:35:00
#29 已发布: 2024/3/3 14:18:11
1,139个赞,共1,805个帖子。
Hi Viacheslav. It looks like a bug.
#30 已发布: 2024/3/4 14:24:55
1,558个赞,共1,868个帖子。
As for the last error, this is by design. Function expected as first argument.
Click to enlarge
Here my results:
Click to enlarge
The problem may be related to this
Click to enlarge
I don't know exactly which one is used by the plugin. You can try reinstalling the Microsoft Runtime support library.
#31 已发布: 2024/3/4 17:04:27
1,558个赞,共1,868个帖子。
Updated.
Changes:
- gsl_msc_ver and gsl_msc_full_ver operands added.
Maybe this will help in the future.
Click to enlarge
显示剧透
Links:
1. Microsoft Visual C++ compiler versioning
2. How to Detect if I'm Compiling Code with a particular Visual Studio version?
I do not attach the necessary package with support libraries because I don't know what compiler the project itself is built with. This is done on the build server side and may change from time to time.
All similar plugins have a similar problem.
sergio 2024/3/5 02:59:00
#32 已发布: 2024/3/4 22:19:45
1,139个赞,共1,805个帖子。
Hi Viacheslav. Thanks. I forgot to tell the operating system: Win10 32 bit. I check the 64 bit version and works fine, as you says. The library gsl32.dll seems to need vcruntime140.dll and msvcp140.dll. I see if I can update Microsoft Runtime support library also.
#33 已发布: 2024/3/5 00:54:12
1,558个赞,共1,868个帖子。
There really is a problem with the 32-bit version of the GSL. I can't debug the function because it gives me an error. This may be due to the project settings for building the 32-bit version of the plugin.
P.S. Only some of the functions in the 32-bit version of the library do not work.
Alvaro 2024/3/5 12:49:00
#34 已发布: 2024/10/8 22:38:03
Lupus the Canine
Lupus the Canine
0个赞,共7个帖子。
Would it be possible to correctly handle units in formulas. Right now, units are present in the first step but then stripped away breaking formulas.
#35 已发布: 2024/10/8 22:51:35
1,558个赞,共1,868个帖子。
I'll think about it. There are about 30 types of solvers supported now and I'll need to rework them all. If I can rework a few solvers, I'll use that experience to update the rest. But I can't promise anything yet.
