Page History: Examples
Page Revision: 2011/11/15 21:35
Engineering
  • Engine Heat Rejection Calcs - good example of working with relative temperature differences (US Customary Units) pdf zip
  • Calculate the Area Properties of Composite Rectangular Areas (US Customary Units) pdf zip
  • Design of Reinforced Concrete Beams according to NZS 3101-95 (SI Units) pdf
zip
Financial
Numerical methods
Statistics
  • Normal distribution pdf zip
  • F-distribution pdf zip
Civil Engineering Hydraulics/Fluid Mechanics
From college courses by G. Urroz
