Page History: Examples
Page Revision: 2013/01/01 13:22
Engineering
  • Engine Heat Rejection Calcs - good example of working with relative temperature differences (US Customary Units) pdf zip
  • Calculate the Area Properties of Composite Rectangular Areas (US Customary Units) pdf zip
Financial
Numerical methods
Statistics
  • Normal distribution pdf zip
  • F-distribution pdf zip
Data Manipulation
  • Importing data from csv files pdf zip
Civil Engineering Hydraulics/Fluid Mechanics
From college courses by G. Urroz
  • CEE Fluid Mechanics Test 1: | Prob 1: pdf zip | Prob 2: pdf zip | Prob 3: pdf zip |
  • CEE Fluid Mechanics Test 2: pdf zip | CEE Fluid Mechanics Test 3: pdf zip
  • Video examples of calculations with units for hydraulics: See Part 2 SMath Studio\
  • CEE 3510 HYDRAULICS : Spring 2012 Schedule - Each link in the Schedule contains links to examples with SMath Studio solutions for pipe flow, pump-pipeline systems, pipe networks, pumps, and open-channel flow (some examples include solutions using EPANET and HEC-RAS)
Developed by Brett Towler
  • Vertical Velocity Distribution in a Hydraulically Smooth Open Channel: pdf zip
  • Hydraulic Geometry of Rivers: pdf zip
  • Weir Flow using the Rehbock Equation: pdf zip
  • Swamee-Jain Friction Factor Equation for Pipe Flow: pdf zip
Structural Engineering
  • Design of Reinforced Concrete Beams according to NZS 3101-95 (SI Units) pdf zip
  • Steel End-Plate Connection Design - adapted from Krishnamurthy 1978 (US Units) pdf zip
  • Design of Reinforced Concrete Slab - Flexural Reinforcement (US Units) pdf zip
