Page History: Examples
Page Revision: 2013/06/18 07:09
Engineering
  • Engine Heat Rejection Calcs - good example of working with relative temperature differences (US Customary Units) pdf zip
  • Calculate the Area Properties of Composite Rectangular Areas (US Customary Units) pdf zip
  • Calculate properties of generic polygons (perimeter, area, centroid, second moment of area, radius of gyration, elastic section modulus, plastic section modulus, orientation of principal axes of inertia, principal moments of inertia, radii of gyration about principal axes of inertia); multilanguage (ENG/ITA) pdf zip
  • Electrical engineering - calculate current, voltage, real, reactive and apparent power in an AC circuit using the complex domain and using custom units for AC power quantities. pdf zip
Financial
Numerical methods
Statistics
  • Normal distribution pdf zip
  • F-distribution pdf zip
Data Manipulation
  • Importing data from csv files pdf zip
Civil Engineering Hydraulics/Fluid Mechanics
From college courses by G. Urroz
  • CEE Fluid Mechanics Test 1: | Prob 1: pdf zip | Prob 2: pdf zip | Prob 3: pdf zip |
  • CEE Fluid Mechanics Test 2: pdf zip | CEE Fluid Mechanics Test 3: pdf zip
  • Video examples of calculations with units for hydraulics: See Part 2 SMath Studio\
  • CEE 3510 HYDRAULICS : Spring 2012 Schedule - Each link in the Schedule contains links to examples with SMath Studio solutions for pipe flow, pump-pipeline systems, pipe networks, pumps, and open-channel flow (some examples include solutions using EPANET and HEC-RAS)
Developed by Brett Towler
  • Vertical Velocity Distribution in a Hydraulically Smooth Open Channel: pdf zip
  • Hydraulic Geometry of Rivers: pdf zip
  • Weir Flow using the Rehbock Equation: pdf zip
  • Swamee-Jain Friction Factor Equation for Pipe Flow: pdf zip
Structural Engineering
  • Design of Reinforced Concrete Beams according to NZS 3101-95 (SI Units) pdf zip
  • Steel End-Plate Connection Design - adapted from Krishnamurthy 1978 (US Units) pdf zip
  • Design of Reinforced Concrete Slab - Flexural Reinforcement (US Units) pdf zip
