Page History: Examples
« Older Revision - Back to Page History - Current Revision
Page Revision: 2017/09/25 04:36
Engineering
  • Engine Heat Rejection Calcs - good example of working with relative temperature differences (US Customary Units) pdf zip
  • Calculate the Area Properties of Composite Rectangular Areas (US Customary Units) pdf zip
  • Calculate properties of generic polygons (perimeter, area, centroid, second moment of area, radius of gyration, elastic section modulus, plastic section modulus, orientation of principal axes of inertia, principal moments of inertia, radii of gyration about principal axes of inertia); multilanguage (ENG/ITA) pdf zip
  • Electrical engineering - calculate current, voltage, real, reactive and apparent power in an AC circuit using the complex domain and using custom units for AC power quantities. pdf zip
Financial
Numerical methods
Statistics
  • Normal distribution pdf zip
  • F-distribution pdf zip
Data Manipulation and Interpolation
Civil Engineering Hydraulics/Fluid Mechanics
From college courses by G. Urroz
  • CEE Fluid Mechanics Test 1: | Prob 1: pdf zip | Prob 2: pdf zip | Prob 3: pdf zip |
  • CEE Fluid Mechanics Test 2: pdf zip | CEE Fluid Mechanics Test 3: pdf zip
  • Video examples of calculations with units for hydraulics: See Part 2 SMath Studio\
  • CEE 3510 HYDRAULICS : Spring 2012 Schedule - Each link in the Schedule contains links to examples with SMath Studio solutions for pipe flow, pump-pipeline systems, pipe networks, pumps, and open-channel flow (some examples include solutions using EPANET and HEC-RAS)
Developed by B. Towler
  • Vertical Velocity Distribution in a Hydraulically Smooth Open Channel: pdf zip
  • Hydraulic Geometry of Rivers: pdf zip
  • Weir Flow using the Rehbock Equation: pdf zip
  • Swamee-Jain Friction Factor Equation for Pipe Flow: pdf zip
Structural Engineering
  • Design of Reinforced Concrete Beams according to NZS 3101-95 (SI Units) pdf zip
  • Steel End-Plate Connection Design - adapted from Krishnamurthy 1978 (US Units) pdf zip
  • Design of Reinforced Concrete Slab - Flexural Reinforcement (US Units) pdf zip
  • Single span moment & shear envelopes for HL-93 loading using influence lines pdf zip
  • Design of a single span simply supported timber beam according to EN 1995-Eurocode 5 (SI units) pdf zip
