Page History: Examples
Page Revision: 2010/01/06 04:02
Engineering
  • CEE Fluid Mechanics Test 1 (G.Urroz) - Prob 1 pdf zip - Prob 2 pdf zip - Prob 3 pdf zip
  • CEE Fluid Mechanics Test 2 Solutions (G.Urroz) pdf zip
  • CEE Fluid Mechanics Test 3 Solutions (G.Urroz) pdf zip
  • NASA's Atmospheric Model (SI Units)zip
Numerical methods
  • Newton-Raphson method for solving equations pdf zip
  • Runge-Kutta 4th-order for single 1st-order ODE pdf zip
  • Runge-Kutta 4th-order for systems of ODEs pdf zip
  • Runge-Kutta 4th-order for single 2nd-order ODE pdf zip
Statistics
  • Normal distribution pdf zip
  • F-distribution pdf zip
