Page History: Examples
Page Revision: 2010/09/23 18:46
Engineering
  • CEE Fluid Mechanics Test 1 (G.Urroz): | Prob 1 pdf zip | Prob 2 pdf zip | Prob 3 pdf zip |
  • CEE Fluid Mechanics Test 2 (G.Urroz) pdf zip
  • CEE Fluid Mechanics Test 3 (G.Urroz) pdf zip
  • Video examples of calculations with units for hydraulics: videos
Numerical methods
Statistics
  • Normal distribution pdf zip
  • F-distribution pdf zip
