Page History: Examples
Page Revision: 2011/02/09 12:33
Engineering
  • CEE Fluid Mechanics Test 1 (G.Urroz): | Prob 1 pdf zip | Prob 2 pdf zip | Prob 3 pdf zip |
  • CEE Fluid Mechanics Test 2 (G.Urroz) pdf zip
  • CEE Fluid Mechanics Test 3 (G.Urroz) pdf zip
  • Video examples of calculations with units for hydraulics (G.Urroz): See Part 2 SMath Studio
  • Examples of specific energy calculations for open channel flow (G.Urroz): See second link in this page
  • Examples of pipe friction calculations for single pipelines (G.Urroz): See second and third links in this page
  • Examples of pipe systems with friction and minor losses (G. Urroz): See third link in this page
  • Examples of pipeline-and-pump systems with friction and minor losses (G. Urroz): See various links here
  • Engine Heat Rejection Calcs - good example of working with relative temperature differences (US Customary Units) pdf zip
Numerical methods
Statistics
  • Normal distribution pdf zip
  • F-distribution pdf zip
