Page History: Examples
Page Revision: 2011/02/09 13:22
Engineering
  • Video examples of calculations with units for hydraulics (G.Urroz): See Part 2 SMath Studio
  • Examples of specific energy calculations for open channel flow (G.Urroz): See second link in this page
  • Examples of pipe friction calculations for single pipelines (G.Urroz): See second and third links in this page
  • Examples of pipe systems with friction and minor losses (G. Urroz): See third link in this page
  • Examples of pipeline-and-pump systems with friction and minor losses (G. Urroz): See various links here
  • Engine Heat Rejection Calcs - good example of working with relative temperature differences (US Customary Units) pdf zip
Numerical methods
Statistics
  • Normal distribution pdf zip
  • F-distribution pdf zip
Civil Engineering Hydraulics/Fluid Mechanics
From college courses by G. Urroz
