Command Prompt
Modified: 2016/09/19 23:54 by w3b5urf3r - Categorized as: English
It is possible to perform operations from Windows Command Prompt (cmd.exe)
Edit
Commands
You can see the list of supported commands using:
SMathStudio_Desktop.exe -silent -?
CMD help
Edit
-s or -silent
this flag enables the shell commands.
Edit
-? or -help
Prompt the help.
SMathStudio_Desktop.exe -?
Edit
-e or -export
Export worksheet(s) to supported formats.
SMathStudio_Desktop.exe -silent -e .html worksheet.sm
SMathStudio_Desktop.exe -silent -e .smz worksheet.sm "worksheet 2.sm" "worksheet 3.sm"
Edit
-i or -info
Provide a flag to display current SMath Studio installation details.
SMathStudio_Desktop.exe -silent -i
Edit
-o or -options
Specific context options. Usually used on export. This flag may be used in some specific file-export plug-in to enable options from command prompt.
SMathStudio_Desktop.exe -silent -e .html -o images=embedded worksheet.sm
Edit
-p or -print
Initiate printing of the worksheet(s) using specified printer. Set "default" to use system default printer.
SMathStudio_Desktop.exe -silent -p default worksheet.sm
SMathStudio_Desktop.exe -silent -p default worksheet.sm "worksheet 2.sm" "worksheet 3.sm"
SMathStudio_Desktop.exe -silent -p "Microsoft XPS Document Writer" worksheet.sm
Edit
-t or -test
Perform testing of the worksheet. Testing allows to verify that all calculations in the worksheet are returning the same results as last save and no new errors appear. You can even specify a path to tests all the worksheets contained into a folder.
SMathStudio_Desktop.exe -silent -t worksheet.sm
SMathStudio_Desktop.exe -silent -t worksheet.sm "worksheet 2.sm" "worksheet 3.sm"
SMathStudio_Desktop.exe -silent -t "C:\whatever"
Edit
-w
Provide maximum time in milliseconds (ms) to wait for calculation of a single worksheet. Calculation will be aborted if this time limit exceeded. 1 hour is set by default.
SMathStudio_Desktop.exe -silent -t worksheet.sm -w 60000
SMathStudio_Desktop.exe -silent -t worksheet.sm "worksheet 2.sm" "worksheet 3.sm" -w 60000
Edit
History
  • SMath 0.96.4902 (Nightly build): Added ability to export files to supported formats using command prompt;
  • SMath 0.98.5914 (Nightly build): Ability to print worksheet using command prompt implemented, Command prompt interface extended to allow worksheet testing;
  • SMath 0.98.5918 (Nightly build): Implemented ability to specify printer name when printing from command prompt;
Edit
See also
Edit
References
  • how to access help command: Forum
