Summation error - imaginary i as sum iterator
Summation error - imaginary i as sum iterator - Changed summation behaviour? - Messages
#1 Posted: 3/18/2018 5:55:24 PM
Jan Claeys
Jan Claeys
2 likes in 25 posts.
Dear all,
Some years ago, I worked out a beam calculation tool in smath, based on singularity functions.
The sheet worked flawless in an older SMath version, but the most recent SMath-incarnations result in problems: the error seems to originate with the summation command.
How do I get this program working again?
I attach the original files: thanks for any feedback!
Kind regards from a Belgian SMath-fan,
Jan
Original file with summation error.sm (143.1 KiB) downloaded 1336 time(s).
Original file working.pdf (190.36 KiB) downloaded 823 time(s).
#2 Posted: 3/18/2018 6:25:11 PM
2,343 likes in 4,055 posts.
Hello.
This is because of using "i" as a variable. Currently we have some issues regarding it. Will be addressed soon.
Simple change to fix your worksheet:
janclaeys 3/19/2018 8:16:00 AM
#3 Posted: 3/19/2018 12:27:26 AM
Hello.
Alternately: define the summations as local variable [SS 6179]
The document concludes the project.
Original file with summation error(1).sm (147.86 KiB) downloaded 1284 time(s).
#4 Posted: 3/19/2018 8:16:29 AM
Jan Claeys
Jan Claeys
Thank you Andrei & Jean for the fast feedback!
