Unit problem
Unit problem - Messages
#1 Posted: 11/22/2011 2:42:41 PM
oalfishcivil
oalfishcivil
0 likes in 1 posts.
a:=10 ft
b:=a^4
b= The program can't recognize ft^4.
Is there any way to do this?
Thanks
#2 Posted: 11/22/2011 5:01:32 PM
Do not understand?
[LIVE width=170 height=130]http://smath.info/live/?file=3270[/LIVE]
Just change m^4 into ft^4
#3 Posted: 12/14/2011 7:50:05 PM
amit28it
amit28it
0 likes in 16 posts.
a:=10 ft
b:=a^4
Thanks
In the above explanation is cryatal clear .
So b = 10000 ft^4.
#4 Posted: 12/14/2011 11:32:10 PM
Edward Ulle
Edward Ulle
20 likes in 182 posts.
Unlike MathCAD you have to type a single quote (') before typing the units.
a:=10'ft
For the second b= go to the end of the line and type ' and enter ft^4
[LIVE width=200 height=300]http://smath.info/live/?file=3372[/LIVE]
Ed
#5 Posted: 12/15/2011 8:21:59 PM
Waluyo Adi Siswanto
Waluyo Adi Siswanto
1 likes in 55 posts.
Using ' before typing unit is a new information for me. Thanks. Defining a unit can be faster.
Usually I just type with the unit what I want, then select from the unit selection under the cursor. For example I just type MPa then select unit MPa. Never use ' before.
#6 Posted: 12/15/2011 11:29:31 PM
Edward Ulle
Edward Ulle
You can actually define units either way. With or without the need for single quote. I like the single quote to be consistent with other units and so it appears in the units style of display.
[LIVE width=400 height=300]http://smath.info/live/?file=3373[/LIVE]
Ed
