Visible or not visible component
Visible or not visible component - Visibility of a component depends on the result of the logical function. - Messages
#1 Posted: 5/10/2017 9:40:04 AM
Janusz
Janusz
0 likes in 6 posts.
I propose to add the new feature: a component is visible or not visible. It should depend on, for ex., result of the function "if". If calculation_type=1 then (dw is visible) and (gw is not visible) else ... This option will allow to make the display of the data elements dependent on the type of the calculation element. p.s. Very nice and useful software!
#2 Posted: 5/10/2017 1:49:55 PM
The way I interpret you demand is like:
conditional compute/not compute.
In some way we have that already.
How to code invisible ? Hello Gurus !
Visible.sm (12.18 KiB) downloaded 1559 time(s).
#3 Posted: 5/11/2017 4:00:41 PM
Arie
Arie
94 likes in 285 posts.
I think this exists as a plugin. Check out conditionally formatted labels plugin. More info here: http://en.smath.info/forum/yaf_postst2100_Conditionally-Formatted-Labels.aspx
Davide Carpi 5/12/2017 6:32:00 AM
#4 Posted: 5/11/2017 8:33:29 PM
Ah ! The forum has crashed for me.
Can't see all previous messages [Martin, Davide ...]
Image Spot True_False.sm (31.61 KiB) downloaded 1598 time(s).
#5 Posted: 5/11/2017 11:12:01 PM
... added simpler spot, neat.
Image Spot True_False.sm (47.12 KiB) downloaded 1527 time(s).
#6 Posted: 5/12/2017 11:12:33 AM
Hello Janusz,
Please, give more hint of what you wish. Previous replies vanished in the wind.
By default, some component(s) don't compute.
"Pixels not in the Map are black because undefined elements matrix are zero by default".
If it works for you: increase "kmax, kkmax" [my 1.6GHz very slow].
Pattern Cahos 4150 [RGB].sm (94.69 KiB) downloaded 1339 time(s).
#7 Posted: 5/14/2017 3:50:38 PM
Ernesto
Ernesto
13 likes in 74 posts.
Janusz,
A limited way of doing this is to right click your if statement (or any operation) and deselect "Display input data".
This leaves you with only the result printed out.
#8 Posted: 5/15/2017 6:33:05 AM
The "if/otherwise" is common in Engineering. A less common "if"
is the the "on error", implemented as "try/on error" [6179].
In some other way, it is a "compute/not compute" component(s).
Visit this gorgeous application. 7min [1.6 GHz micro laptop.
Image Rotate RGB.sm (349.66 KiB) downloaded 1590 time(s).
Few things have changed in the forum ! ?
#9 Posted: 5/15/2017 7:07:43 AM
... compute/not compute can be "bolean" too .
Random fill this Gaussian region.
Random Fill Range PDF.sm (39.45 KiB) downloaded 1533 time(s).
