1 Pages (8 items)
[SMath Viewer PRO] SV vs third-party plug-ins (Regions) - Commercial Smath Viewer does not display the graphical X -Y Plot - Messages
#1 Posted: 7/28/2016 1:48:55 PM
Human eye.sm (6.4 KiB) downloaded 1198 time(s).
Human eye_Comm_and_Free.zip (1.07 MiB) downloaded 345 time(s).
#2 Posted: 7/29/2016 9:17:27 AM
Hello Carlos,
I haven't understood what the Viewer was designed for. That's personal only.
Maybe for the facility to add comments ? In this typical image, I can add as
much as desired to a accommodate each particular application.
I understand your point: Commercial Viewer does NOT capture the plot.
#3 Posted: 7/29/2016 1:05:27 PM
Hi Jean :
Thank you for your comments.
I explain how I see the use of Smath Viewer.
A program was developed to calculate or design something , in order that almost anyone can use it with minimal knowledge.
The person using it , simply by changing the input data , this can calculate or design element in smaller or larger size .
The person does not see the formulas or source code . Then Smath Viewer is ideal to be used by almost anyone .
In my case, I am trying to develop a program to calculate and design Wastewater treatment Activated Sludge fine bubbles Plants .
The graphical X -Y plot , use it to graphically display the distribution of air diffusers .
Some screenshots
Small Plant (two diffusers).
A slightly larger plant (60 and 48 diffusers)
Some screenshots
4 users liked this post
frapuano 7/29/2016 1:30:00 PM, Ernesto 7/29/2016 3:30:00 PM, Davide Carpi 7/30/2016 5:04:00 AM, Andrey Ivashov 8/5/2016 11:27:00 AM
#4 Posted: 7/29/2016 8:26:04 PM
Thanks Carlos. A great tool the Viewer !
#5 Posted: 8/5/2016 11:29:42 AM
WroteCommercial Smath Viewer does not display the graphical X -Y Plot
This is because SMath Viewer Pro doesn't support third-party plug-ins (because of technical challenges). I'm working on it...
#6 Posted: 8/5/2016 3:34:52 PM
Andrey
Thanks for your reply-
But I have curious to know , because the free version of Smath Viewer does support the Plugin X -Y Plot, and PRO version does not , if it is assumed that the PRO version has more features .
#7 Posted: 8/5/2016 6:11:22 PM
You are right. But the reason of why SMath Viewer Pro costs nothing is that it is not actually ready yet.
It will support third-party plug-ins when I will implement it.
1 Pages (8 items)
