Copy and paste only work following opening a second file
Copy and paste only work following opening a second file - Copy paste only becomes available when a second file is opened - Messages
#1 Posted: 2/26/2020 7:21:25 PM
Kriss Cringle
Kriss Cringle
3 likes in 15 posts.
The copy paste functions only become available when a second file is opened. When you first open Smath (a single file open) the copy / paste buttons are greyed out. Once a second smath file is opened then the facility to copy paste is available.
In addition and this may be connected, when print is chosen it only works the second time it is clicked.
I'm hoping this can be resolved in the next version. Cant see any other people with same issue so it could be just my setup?
Kind regards
Kriss
#2 Posted: 2/26/2020 9:01:38 PM
Nothing true pertaining to an installed Smath.
You may have to first install all available plugins.
Lately, the latest SS 7251 was still 'Beta'.
However, no such booboos were reported.
#3 Posted: 2/27/2020 9:35:39 AM
1,442 likes in 2,934 posts.
Hello Kriss,
I cannot reproduce. What is your setup? (Program Version, OS)
How you open the file the first time? (double-click on the file, launch the program then open the file...)
#4 Posted: 2/27/2020 11:50:05 AM
Kriss Cringle
Kriss Cringle
Hello Kriss,
I have windows 10 home 64 bit
SMath Studio desktop 64-bit
version 0.99 (build 7030)
The cut / copy / paste thing appears to be an intermittent fault. I will try to make a note of the steps leading up to it the next time it happens
The printing bug is still there. When I click print the print dialog box comes up but then when I click print nothing happens until I click print a second time.
Many thanks
Kriss
#5 Posted: 2/27/2020 12:51:59 PM
Try Print Preview ... attach document [all or part].
Download "CutePDF" install as virtual printer,
Try to print as *.PDF ... give name to *.PDF document.
#6 Posted: 2/27/2020 1:09:52 PM
That double click you mention, may have to do with your Win 10 ?
#7 Posted: 2/27/2020 1:32:52 PM
Please try following this guide if with the latest beta you still have those problems.
