Equation number in a
Equation number in a - Messages
#1 Posted: 11/4/2017 5:04:03 PM
Paulius
Paulius
0 likes in 11 posts.
Then writing master thesis I need numbering equation there's a methods to put number on equation, or simple I need put the text near formulas. Example:
3+4=8 (101)
2+3=5 (102)
#2 Posted: 11/5/2017 6:43:35 AM
Hello [userlink]Paulius[/userlink],
You can start writing a text region simply by typing the double quotes character (") anywhere in the canvas
You can even use the description area (right click on the math region -> show description) and move it to the side you want dragging his left edge.
#3 Posted: 11/5/2017 7:17:33 AM
Equation [1], [2] are one line, they lineup nicely.
For equation of num/den style: use a construction line
that you will delete after construction.
#4 Posted: 11/5/2017 7:46:56 AM
You can highlight a graph or any math region simply:
1. capture the graph frame using "WinGrab" [freeware]
2. crop the Wingrab selected region
3. copy/paste in IrfanView, inverse colors
Inst_Mach Number Pitot [PUBLISH].sm (30.78 KiB) downloaded 1073 time(s).
